PLC Pie Guy
So,, Why not figure out EXACTLY how many pulses per rev you are getting. Use that value times the 104 and then you should have your SCP input upper limit and the HSC reset Value...
Does the encoder actually say 1024 pulse/rev on the label? Silly question I know but it seems like something isn't right with the amount of pulses your getting vs the math and values you are using.
