RSview32
I vehemently disagree. That title surely belongs to Windows Vista.
Everything else Ken said, I wholeheartedly endorse :nodi:
I must disagree with you, Windows ME is hands down the worst. Makes 8 look like a gift from the gods.
Hi Sir (Ken)
i got one more problem when i try to open program in demo version its showing "Windows cannot find D:\ Documents and ......File name(sij045.rsv',) Make sure you typed the name correctly, and try again
Hi Every one
i got one more problem when i try to open program in demo version its showing "Windows cannot find D:\ Documents and ......File name(sij045.rsv',) Make sure you typed the name correctly, and try again[/quote]
Maybe the project isn't really an RSView32 file, or maybe the path length is too long.
Try putting the *.RSV file into a short path folder like D:\HMIProject\
These are all odd issues. Out of the box installation on XP should be very easy. Did you get this software from Rockwell? I thought you were trying a demo? Now it seems like you are trying to move an activation file?
hello sir
yes u r right im trying to install demo also i downloaded now its showing "data base exceeds the maximum supported by your software Aborting Project load"
hello sir
Sounds like you are trying to open a project that has more tags than the software allows.
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
372
Hi everybody, I have a rsview32 application, when I try to run it it loads upto 80% system settings and the crashes saying Rsview32 Project...
1,906
Hi Guys I'm having trouble assigning a tag to an activex label on a Multipage Tab. I can assign the tag to an active x label on a normal display...
596
I have followed the procedure below to convert RSView32 project to FactoryTalk View...
1,431
I have converted RSV32 to FTVSE Distributed. pretty straightforward... I cant seem to figure out how or find any documentation to migrate RSV32...
2,303
