Red Lion G3 and Ultra 3000
Rick Densing
Apr 2002
Milwaukee, WI
1,538
I am trying to use a Red Lion G306 to change the index positions and speeds on a Ultra 3000 drive via RS-232.
I see Kolyur was successful here:
http://www.plctalk.net/qanda/showthread.php?t=22687
I am just having a little trouble setting the tags. I tried a gateway block, which works great for reading current position and velocity, but keeps writing a zero to my positon block. Anyone have any advice on how to configure the tag?
If you are going direct from the hmi to the Ultra you wouldn't need gateway blocks. You will be able to create data tags and map them to the appropriate values in the ultra. Feel free to email me your current file at [email protected]
Jeremy
Working on a new project where I'm trying to use a Ultra 3000i servo drive and a Red Lion G3 servo to be do the following: 1. Feed material...
3,351
Customer had to replace a G308K HMI panel because of a burned out backlight. They got a replacement unit, downloaded the .cd2 file to it and it...
2,915
While they came up quickly with a fix for the alarm date issue quickly I will have to drive around for a week or so, burning up a lot of fuel...
262
From the Red Lion website, after some customer enquiries in the last week or so... Rev. March 25, 2024 [18:30] Just thought it might help a...
278
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
107
