can someone shed some light on this topic
plc noob
Oct 2007
atlanta , georgia
258
a properly rated emergency power disconnectshould be used to power the plc controlled system as a means of removing powerfrom the entire control system . it may be necessary to install a capacitor across the disconnect to protect agianst a condition known as outrush . this condition occurs whenoutput triacs are turned off by powering off the disconnect. thus causing the energy stored in the inductive loads to seek the shortest distance to ground which is often through the triacs .
Sounds like the PLC manual is asking for a "surge suppressor" to be installed across the output to protect the triac. Most of these AC suppressors are a combination resistor and capacitor.
In the old days this was a common requirement when a mechanical switch was wired in series with a solid state PLC output.
Does anyone know of a way to detect if someone is online with the controller in ControlLogix (from logic) I'm thinking that maybe there is a CIP...
376
Long story short lost our parameter setup for an indradrive m. I have these files saved as backups but dont know how to open them. Can someone...
898
If a programmable controller controls the operation of a motor, what connects motor control to the PC? A) Line voltage B) I/O device C) Modem D)...
27
7,085
I can't find what laptop I have our PanelBuilder32 application and license on. And Rockwell no longer supports it. Can someone please update 1...
1,622
I recently started getting "corrupted or low disk space" errors on all my backup panelbuilder32 files seemingly out of no where (been running ver...
1,596
