I'm just making some notes about the resistors for DH & RIO networks.
I know the advice is for 150ohm for 57 - 115k, and 82 Ohms for 230k. I also read that it's 82 ohm for RIO
My understanding is that the resistors match the characteristic impedance of the cable, in the case of Blue Hose that's 78Ohms, so I can see the sense in 2x 150Ohm resistors being 75 Ohm in parallel, which make the signal think its an infinite run of cable to stop any reflections.
Am I right in thinking that the 230k network uses the lower resistance terminators because the increase in frequency drops the characteristic impedance of the cable down? I guess to circa 40 Ohms?
Moving onto RIO cables (with SLC PLCs in mind), I found info suggesting 82 Ohms for these? but wouldn't that be dependant on the network speed again? Not done a lot with setting up RIO on these really.
Another question - whilst I'm here!
Does mixing drop-line (with station connectors) and daisy chain seriously effect performance, or is it only marginal? I know the official idea is that you should not mix them. I'm trying to work out why that is?
Andy
Andy
