KepwareEX OPC client value is BAD in citect
What have you set up on the kepserver?
For example what plc are you connecting to with kepserver, then before connecting citec you can run the OPC Client in kepserver to see if you are getting data from the PLC.
device is a RSLinx OPC Server connected to RSLogix Emulate. The OPC client is showing data. is license required for citect?
To be honest I have no idea, however it is possible that if you have a demo version then it may not communicate with OPC or other driver, perhaps someone else knows. If it is RSL opc (suppled by kepware) that came bundled with factorytalk or what ever it is called now it may not work RW are not going to give you anything for free that connects to other equipment I bet.
I know Kepware (supplied by them will work for two hours you then have to re-start it), as for Citect I could not tell you. I do not know citect, can you browse the OPC space with Citect ? most Scada systems have the ability to import the tags, if so it should be able to read the data.
This seems a bit confusing, the OP stated it was Kepserver (often bundled with FTView) but now he is talking about RSLinx which is it.
Hi All, I had a question regarding Kepware. I was able to pull in data from my PLC tags along with the tags coming from the third party OPC...
1,091
Hi, I am struggling to resolve a problem with Kepware OPC server. I got to read some array elements from an Energymeter to my RSView. Normal tags...
7,627
I've posted this on the ptc forum as well, but no luck with an answer (waiting for my service contract number) I keep getting the following error...
119
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
223
I know nothing about simaticnet OPC server. I do know Kepware. I would only ever scale raw to engineering in the PLC, but it is possible to scale...
215
