Running VMs off external USB HD. Regular HD or SSD ?
Cant comment on the VM but for the cost of SSD now, there isnt ANY reason why the whole PC shouldn't run on a SSD, or to run anything else on anything but a SSD. You can get a 1TB samsung on amazon for $250.
I switched mine to all SSD about a year ago and my stress level is lower, I find myself having extra time on site to tour and shoot the ****.
If I added up all the billable time I waited on a conventional hard drive to do what the hell I told it to do it would probably be in the 25K range.
If you're not using SSD then your wasting a lot of time you could have back, it really is that big of a difference.
Thank you for that. I knew SSD were faster but this pretty much made my mind up as a must have.
Forgive my ignorance but isn't RAM a bigger concern? I would guess you need at least 16GB Ram to run a couple of VM's efficiently
I'm looking to replace my old precision laptop, but so lost on all the new hardware and vendors available today. The rugged laptops I've seen lack...
18
3,349
Hi, my laptop running a bit slow and starting to test Linux. What I want to do is use Linux as my main operating system as its not as resource...
3,011
The maintenance shop laptop for the electricians just died and I need to buy a new one. We have a huge mix of controllers requiring different...
17
5,955
I have no experience with Eaton HMIs. I downloaded the Galileo software and I am trying to get the file on a HMI (XV-102-H3-70twrl-10) to modify a...
101
How to fix if appears code “$115 plc-restart running” on the screen OP17
244
