androcci
Hello, I am struggling to find a block that does the exact same thing.
the A/M block has everything a PID has except for the CV and PV.
the (A) input receives an analog signal from a PID output. if is in automatic then [(A) = output] of the A/M Block
If I use the PID then if I put it in automatic I will modulating about the SP and I dont want that.
the TC input if TC=1 then the output will equal the TV input
if the user press the button to go in manual it will just take that input.
I know that the TC & TV is the same as the CVinitreq & CVinitValue.
but I cannot find a way to have a block with selection of Manual and also have a second input to by pass it to the output.
Pretty much I need an block that;
Makes the output= input
takes manual input from the operator which I know I can just tag it. I hope I am making my problem clear. I know I cant do it wit the PIDE.
THANK YOU so much in advanced guys.
