shaneprasad
Hi guys .... we have a new 50amp 3 phase water pump to supply water for our new machine. Just want to know what would be a suitable starter for this pump. Basically the only tme this pump would be switched on when the production is running on that new line. We do not require a pressure switched control system. The pump will run continuosly while the production is running. Can we fit a 50amp DOL starter. What do you guys recommend? Your help highly appreciated. Thanks
