eastkodakguy
Hey all,
I need some help on a couple of things first off (E Stops)
Is it safe to use an ordinary relay as an estop relay(mcr)? If so what is the advantage of using specialized relay like an ab guardmaster relay? If an ordinary relay will not work
what specs does the relay have to have to be considered
an ESTop relay
(secondly Circuit breakers
Here is an example of what i am trying to do
460 to 120vac control transformer 2kva
My wire size on my 120vac side is 12awg
Hot*****CB***********Control panel lighting*****neutral
Hot
Hot*****CB***********PLC power supply***********neutral
Ok so my question is Would I size my circuit breaker to the ampacity of the wire (nec Tables) If not what should I size it to?
an ESTop relay
Hot
