If you can connect to the drive before trying to download the 4 items (tags) you're trying to add, I would try uploading the drive parameters, and if there are no errors there, download 1 additional item at a time until you see which is causing the error. I have added the tags for Output Current, Voltage and Frequency as well as Drive Temp on 50 or so of these drives with no issues at all.
