Compact Logix L32E/L30ER printing to Ethernet Printer(Zebra)
We do printing to Zebra's over TCP Socket frequently, works just fine. We also do it with Siemens, which is just as capable with a CP card installed. Your ZPL build strings are the same as they would be over RS232, its just a different chunk of code to get them to the printer over TCP/IP.
Do you mean Ethernet/IP with special firmware? or straight from Compactlogix/Contrologix to Zebra with an RTA Gateway?
Just straight from the processor/Ethernet Module. What is the PN of your Ethernet Module? ENBT/EWEB/EN2T, etc. Some of the older modules don't support socket interface.
I dont have a particular one, but it can be a compactlogix. Did you use version >v20 with Zebra LinkOS AOP or a generick E-net module define with I/O Assembly instance?
Hi Travis, can you share the one with siemens?
All, I have a system on a CompactLogix L32E with Devicenet. I need to flash the 1769-SDN Devicenet module to a higher rev. after flashing up the...
1,224
Im on site, there was water damage in the cabinet. Trying to see what i can do Right now here is there. I can see all inputs, and LEDs work...
2,553
Hey Guys, Just learned Rockwell stopped selling these two processors as of 12/2020. The web page recommends moving to the 5380 platform. Are...
1,669
Good morning, I am having some issues connecting to my plc via ethernet. There is a 9-pin RS232 I can connect to however. The ethernet cable...
1,865
I am trying to setup communications between an m580 and a compactlogix plc. I have confirmed my set up on schneider side is correct and now I am...
2,999
