Relaince automax PLX communications
stallone
Oct 2010
south africa
172
Hi all,
I have a very old reliance automax PLC system in a packaging machine, which we cannot upgrade now at this stage, the communications go via a passive tap bnc connectors to my SCADA pc and connects to the BNC port on the Ethernet card within this old pc, running windows 3.11 and wonderware touch.
My problem is this pc is becoming very problematic and i need to change the pc.
I have the backup of the wonderware scada program.
What options would i have to upgrade this pc with today's technology, either a new pc with different comms options but still connecting to the passive tap/plc and maybe a converter from bnc to Ethernet perhaps?
Windows 3.11 ?
Do you still have the Windows 3.11 installation floppies?
First thing I would try is looking for another OLD computer and see if
it will even run Windows 3.11. Second thing would be to try installing
the required softwares on a newer machine - maybe XP - and see
if you can find a newer computer that can run it.
I had had good luck taking a Windows 2K ghost image, and 'dumping' it
onto a new computer then letting Windows sort things out. After
removing the NIC from the old computer and getting the communications
set up on the newer computer I got things working.
But Windows 3.11 to something more modern . . . Good Luck.
Poet.
Is the computer problematic because of the computer?
Or is it the hard drive going bad?
(And if it is the hard drive . . can one even find a hard
drive small enough that is compatible with Windows 3.11?)
Would the latest 'Wonderware' work with that old PLC?
If so maybe some sort of media converter and go with a new PC?
Poet.
Good Morning All! I have a machine we recently install with an Automax control and Drive system. I need to maintain this and make improvements...
610
Good day everyone. I am installing a used machine with an Automax control and drive interface system. This rack has 2 processors a 57C435 and a...
1,984
We just got a new to us, used machine. It has 2 Automax racks with 3 Drives and associated I/O. How does a person print out the blk files to look...
17
3,876
Hi all, i have system running reliance automax plc system and drive system. The scada systems are wonderware intouch ver 5.0b. the automax plc...
1,451
Anyone seen remote I/O adapter with fault flashing and says "ESO LOS"
1,446
