I am working on sizing a compactlogix plc based on user memory. Allen Bradley uses the following protocol below. Can someone explain what is defined as a controller task? Is this essentially every instruction task I will be using in the logic is considered as 1 controller task? ie an XIC is considered 1 task?
Estimate Controller Memory Use
The following equations provide an estimate of the memory needed for a controller.
Controller Tasks _____ * 4000 = _____ bytes (minimum 1 task)
Digital I/O points _____ * 400 = _____ bytes
Analog I/O points _____ * 2600 = _____ bytes
Communication modules¬ _____ * 2000 = _____ bytes
Motion axes _____ * 8000 = _____ bytes
FactoryTalk alarm instruction _____ * 1000 = _____ bytes(per alarm)
FactoryTalk subscriber _____ * 10000 = _____ bytes per subscriber)
