As you may have guessed this is for Peter but anyone can join in.
In the attached plots look at the ram @ 17.2 This is a quick move (open loop move) This means the motion control ramps up to an output then ramps down to stop in the position. At 17.2 the axis stops and goes the other direction. I am using the pressure limit firmware and I am being told that this could be a firmware problem. The machine was only doing this a couple of times a day so I was very lucky to get such good plots.
I was able to change this to a regular closed loop move command and it seems to work correctly. My problem is I realy like this quick move command. Some of my machines have jack cylinders that make the fast moves. With this command I can do all my tuning with the large tonnage cylinder then use this open loop quick move with the jack cylinders. I was told I could do the same type of motion by using the O open loop command. The hard part would be accel & decel.
Any suggestions?
Any suggestions?
