|TrUlZ| Member T Join Date Jan 2012 Location OSLO Posts 2 Jan 27, 2012 #1 Helo I have a FB-Libary in Step 7 v5.4 i want to use in TIA-Portal V11 Sp2. How can i convert this?
JRW Member Join Date Jun 2002 Location South Carolina Posts 2,301 Jan 27, 2012 #2 From the Portal view- use the migrate button
|TrUlZ| Member OP T Join Date Jan 2012 Location OSLO Posts 2 Jan 27, 2012 #3 After the old program is migrated to TIA. How can i move FB-Blocks between two project? Last edited: Jan 27, 2012
JRW Member Join Date Jun 2002 Location South Carolina Posts 2,301 Jan 27, 2012 #4 Make a global library To do this just drag the blocks and drop in
msl Member M Join Date Mar 2012 Location meeuwen Posts 31 Mar 16, 2012 #5 How does it work if you want to this the other way from TIA V10.5 to Step7
JesperMP Lifetime Supporting Member + Moderator Join Date Feb 2003 Location ᚴᚬᛒᛅᚾᚼᚬᚠᚾ Posts 16,320 Mar 16, 2012 #6 msl, please only post the same question once.
