PLC functional Design Specification and PLC Logic Design
Be direct with the client and ask for specifics. Most likely you will write something out and send to them, then they will send it back to you asking for more information. May as well get all the criteria and conditions they are looking for before you start writing it?
There are two ways to write a functional spec as an integrator:
1) If the customer hired you because they don't know what they are doing and they trust you to be the expert, then you write how you think the system should work.
2) If the customer knows exactly what they want, and just want you do to the work for them, then the trick is to get all the stakeholders in the room long enough to agree/decide/tell you. Also, sometimes figuring out just who the stakeholders are is a trick by itself. It helps to have a first draft of what you think should happen (assuming 75% will be wrong), and then you let them pick it apart and fix everything.
Hi there, i like to know if some of you experienced plc gurus have particular method/s on simplying a plc program written by somone else. whether...
1,707
hi, i am new to this field i have a doubt why we use functional blocks in plc programming and how to use these functional blocks in programming...
25
8,216
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
26
167
I have a project to automate four generator sets. The system will monitor and store the load demand of the factory. Once there's Power outage, the...
49
