Replacement for 1794-AENT
rijuraju
Aug 2017
Mumbai
Is it possibile to use 1794-ACN15(AB ControlNet Adapter) instead of 1794-AENT (AB Ethernet/IP 10/100 Ethernet Adapter) ?
Kindly guide..
That RJ45 port labeled NAP is not Ethernet. Not only will it not communicate with your NIC, it can fry your NIC if you plug into it.
I have 1794-ADN Flex I/O Adapter connected over device-net network with scanner . The I/O and network status led are blinking RED . I have...
2,319
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
126
Hi , I am trying to replace an old inverter with a new one and its giving me issues . Once the new one was installed , the S7-300 PLC started...
126
Hi Everyone, I replaced encoder 842D-60131331BXA with a new same part number. Dip switches and Preset Push button are considered. When I tested...
230
Hello, I am kinda new to automation, I had an issue with 1743-EPAC which supply's 13 IO , when we inspected it there was a short circuit...
143
