ziyaddin2015
The VFD for one of our conveyor motors had failed. Originally when it had failed it had powerflex 40 drive which was upgraded to 525. Yesterday an operator pressed an Estop button while the machine was running which shorted drive. Input voltage was measered at 270 VAC but output was at 4 VAC. The decision was made to swapp the drive. Now were seing an issue with it whenever conveyor stops for downstream it causes an alarm the VFD not ready. It is a resetable fault. Output voltage meausured at 4 VAC again. The drive shows no alarms and communicating properly. I suspect this drive to be a problem from stock. Any help will be greatly appreciated . thanks
