andrzejplo
Hello,
I have a question about Runtime Language Switch in Intouch 9.5.
1.How to change language in Alarm Text in new Intouch 9.5 version? Alarms are integrated with an application so I also want to change their texts.
2.I read in this presentation that new version has possibility of "All Static Text Can Be Switched". It means that I have a text like "Text1" and and a tags named Pump_On_OFF and when Pum_ON_OFF is force to logical 1 in a filed Text1 text "ON" will appear and when tag Pump_ON_OFF will switch to 0 than text "ON" will automaticaly changed to "OFF" . Can I wrote this logic in Script and these texts "ON" "OFF" will also be imported into this XML "LanguageSwitch File?? How can I do something like this?
3.I have 100 Tanks (the same) and I want to use Intouch SuperTag method as a simply way of doing indications popup for each Tank. I will do one Popup with this indications and I want to include headline (Like "Tank 1") depends on which Tank I choose. If I choose Tank33 I want to send Headling or Text "Tank 33" Action Script code is mentioned below: 'Here I Use Super Tags and I send It to the window with indication
STF.Name = Tank1.Name; ShowTopLeftAt( "Tank_Temperat", 500, 210 );
'Here I open my Window with indication. 'How to send a Headling for exaplme " Tank 1 indication" 'which will be transleted with this Runtime language switch
How does this Runtime Language Switch works witch Scripts Is this generaly possible?
If Yes how to do this in Intouch 9.5?? It is very important in using Super Tag Method in my application which I will do in 9.5 version.
