MP377 how to change MPI adres from HMI by pressing a button
genesisfm
Apr 2008
Europe
23
Hello,
I got the following installation:
We have 2 equal HMI displays (MP377) the only different is the MPI adres.
Right now we have to change the MPI adres into the software (wincc flex) and upload the software with the right MPI adres.
My question is, we upload the software by ethernet, can you change the MPI adres from the MP377 by pressing a button on the display? So a use can change the MPI adres for example.
Thank you!
Best regards,
Robert
The MPI adress of the panel is configured in the WinCE operating system.
This cannot be changed from within the WinCC Runtime.
The only change you can make is the MPI of the target station, but this won't solve your problem.
You should be able to use the same procedure when using Ethernet.
If both panels have unique IP adresses.
Set MPI adress in the connections tab, download to panel one, change adress in connections tab, download to panel two.
Hi colleagues.We do data logging system.We want to record three temperatures under a certain condition. We prepared the project as follows. We do...
755
I want transfer an existing MP377 12" key panel to a replacement. I don't have the original project. I tried to take a backup using Prosave...
1,632
I'm still getting used to working with Siemens Step 7 Classic, and WinCC in the Simatic Manager package. I need a trend line on the MP377 HMI, and...
1,841
Hello everyone, I have a strange problem with an MP377 19" panel. Short version is the bootloader seems to be stuck. Normally with these panels...
2,800
Hi, I have a MP377 12 inch touch panel . when turn ON its show only white screen . In the RJ45 two lights always ON. I can't communicate, In...
2,781
