ChristianNondorf
Hello to all. I've lurked for several years and this is my first post...
Does any one happen to know if it is possible to push data back to a RSLogix 5000 AOP instance?
We have several machines at my plant that are running 1769-L33ER processors with each controlling a handful of PowerFlex 525 drives via EIP. I have written the logic using the PF525 AOP and have enabled ADC. Unfortunately, if anyone changes a drive parameter (via HMI or HIM), the next comms cycle wipes it out in favor of the parameter set that the PLC has saved within the AOP. I am trying, unsuccessfully thus far, to find any documentation on how to change a parameter set saved within an AOP instance or how to trigger the AOP instance to "read in" the current parameters from the drive and save them to the file. Obviously this can be done manually from within the program but I would like to accomplish it in an automatic fashion from logic. The end goal is to provide a means to change drive parameters and have the AOP instance save the updated parameters without programmer intervention.
Thanks in advance for any help.
Christian
Christian
