Hello. I have a problem with a pva file. I have to migrate of a panelview 1000 standar to a panelview plus 1000 and i cant open a proyect in a ftview with the pva file. At end apears a message "cant open the proyect.
The pva upload is with panelbuilder32 ver 8.32
somebody help me.
Welcome to the Forum!
PanelBuilder 32 will open both .pva (terminal) and .pba (development) type files; open up the .pva application with PanelBuilder 32 and Save it As .pba.
1. Open up the .pba application using PanelBuilder32 and then, using the Tag Editor utility
change all semicolons';' to colons ':' and all dashes '-' to underscores '_'.
2. Open up FactoryTalk View Studio and create a New Application; give it a name, specify the language and the resolution on the terminal it is intended to run on.
3. Select
Import type PanelBuilder Application (*.pba) then Next.
4. Follow the steps in the Machine Edition Import Wizard.
When you complete the steps of the wizard, FactoryTalk View Studio converts the PanelBuilder application, creates the converted application’s folders and files, and then shows the converted application in the Explorer window in FactoryTalk View Studio.
If there are any messages about conversion, they are shown automatically in the Project Status dialog box.
The converted application is created in \Users\Public\Public
Documents\RSView Enterprise\ME\HMI projects\Application Name where Application Name is the name of your application specified in step 2.
Some of the PanelBuilder 32 objects are not supported in FactoryTalk View Studio and others have similar functionality (not identical) equivalents..
