micrologix 1200 output has voltage
Unlike relay output models, the ML with transistor outputs need to have a DC com connection made for each bank of transistors. Most people forget this or only hook up the DC com to one bank- and then get strange "stuck on" outputs like you're experiencing. Check that first.
This machine has been running fine since it's install 2 years ago.
The output is commanding an allen bradley powerflex 525, forward is output 7 and reverse is output 8.
I've discovered that someone has wired an AB 854K-B24SA3 stack alarm to this same output, probably about a year ago.
I'm thinking this is drawing to much, and has caused the contacts to fuse together. Should have been wired to the control relay...
New PLC came in, downloaded program and installed, working like a champ.
I will have to figure out some kind of workaround for the warning alarm.
You might also want to look into installing a 'reverse-bias diode or other back-EMF snubber across the output' to try to protect the output from having this happen again.
Poet.
I need help achieving the following task: ML1200 sending 4 to 20 mA thru analog output ch0 to a DC speed controller analog input(4 to 20 mA) my...
671
Hi all Have a Micrologix 1200 (1762-L24BXB) There are 2 expansion modules attached. 1x 1762-IQ16 and 1x 1762-OB16. The PLC wired inputs and...
1,029
Hi to all! Can i ask help on this one. i cant seem to analyze what this pin is for many thanks to those who will reply!!!
2,665
Does this mean it can run 24vdc and 120vac relays depending on which of the 10 outputs are used? Whats the difference from OUT 0-9 and VAC DC...
4,904
Hello All, I'm having my first experience with the ML line and their HSC function. It took a bit of head banging but I finally figured out how to...
3,546
