Wonderware System Platform Setup - Need Suggestions
andrewstar03
Jan 2013
Rizal
Hi All,
I have Multiple Galaxies in a Production Plant.
We are working to bring in all the HMI controls into a Centralized Control Room. This room will use ACP ThinManager to serve three clients (Thin Clients). I am looking for a way to have all HMIs from these multiple Galaxies to be deployed into a single Node which will be the Terminal Server (will be setup as Primary and Secondary).
I am thinking of using one of the Galaxies to host all of the HMIs and then deploy it to the Terminal Server node. But the problem with this is (1.) I will need to import all of the Archestra Graphics used by the HMIs, as well as (2.) duplicate the DA Servers from the other Galaxy(not very sure with this). And (3.) future concerns would include implementing modifications made within the original HMI from each Galaxy to the imported HMIs (Intouch viewapp objects), this might cause discrepancy with the HMIs if not done properly.
So I am looking for other ways to implement our plan without too much impact with the existing setup like if there are ways which I could deploy multiple intouch viewapp objects from multiple galaxy into a single node, or just simply integrate all galaxies into one galaxy since this is the best way to deal with issues like this one we are currently facing.
Hope to hear your ideas.
Thanks!
I believe you can do ‘multi-galaxy’ projects almost exactly what you are wanting.
We do want to do something similar, albeit with remote sites/galaxies, but have not approached it yet.
Sounds like a question for your distributor/tech support more so though?
Yes Multi Galaxy configuration is one solution and I am currently working with that. however the main concern for this setup is the Propagation of changes made on the Original (Main) Galaxy to the Objects which is imported to the Paired galaxy.
I already asked for support with the distributor, unfortunately I haven't heard from them yet so I decided to post and hear what other members had to say.
Seems odd that you can make a symbol and place many of them but if the text on a button and or elsewhere in the symbol comes from a Custom...
1,635
I was given some example code but I can not get the function to show up in the System Platform script. The dll import is successful but I'm...
2,028
Hello Everyone! Need help with this... I have a controllogix plc 5571 which has just a USB port on it. I wish to read the data from this plc...
2,384
Need your Advice. Scenario: I have got two SCADA computers at different locations which are having independent working plants at each site (But...
2,936
Hi all, This is my first System Platform 2017 install. Have done plenty of mods to existing 2014 R2 installs and know what I'm doing in terms of...
5,061
