communication between Micrologix 1500 and k-tron controller using Modbus an
m_ansari20
Oct 2005
Pune
i am facing problem with modbus communication between Micrologix 1500 and k-tron controller.
Micrologix 1500 is master and k-tron controller is slave
i can read/ write data to k-tron controller, but the data is receiving in Integer format and i need it in IEEE/FLOAT format.
does anyone gone through this problem?
please sort out the problem
A. M. Ansari
Hi! Last few I've been trying to send message from MicroLogix 1400 to Micro 850. Unfortunately every time I failed :banghead:. Did someone tried...
3,177
Hi there, I am trying to communicate between Siemens 1214 that I have and a Micrologix 1400 on the other end through CIP protocol. I downloaded...
2,028
we use M580 which have an Modbus RTU port correct if iam wrong now should i have to read input data from ab micrologix through read var block and...
1,850
can anyone help me to get IO Data from ab micrologix 1400 to modicon M580 they are connected through ethernet?ip communication
3,217
Hi everyone. I'm using the relay CR30 for security. I have programmed the relay to read inputs and use outputs, and that's easy. I want to know...
1,407
