terminal blocks
porky
Oct 2002
Maia
76
Can someone tell me where in this planet I could buy at short notice din rail mount terminals with a resistance of 250 Ohms.
many thanks
Porky,
These are Allen-Bradley terminals and quite expensive.
(US $11.00 each!) You will have to check with your local A-B dealer for availability if interested. When I ordered mine, they were available at the factory only, my local distributor did not stock them.
1492-WD4RC001 Precision Wirewound 249-ohm
I installed some on a machine (analog inputs and outputs) prior to machine commissioning/calibration and I can put an o'scope on the circuit without interrupting operation. It paid off recently because we had an intermittent problem and I was able to record the malfunction with a data analyzer.
Grover
Hi Porky,
You can buy the WDK2.5E for electronic components from Weidmuller and weld the resistor.
Se Maome não vai à montanha, vai a montanha a Maome.
I'm trying to include MOVs and fuses for solenoid PLC outputs in a panel with limited space. Does anyone know of terminal blocks that have built...
235
What is the difference between Siemens terminal block 6ES7193-6BP40-0BA1 and 6ES7193-6BP40-0DA1? Can they be used interchanged for an analog...
1,224
Currently using a AB 1492-FPK2, plug in fuse but now finding alot of these are.. touchy with connections. the terminal block they are plugged into...
1,354
OK, some internal "discussion" going on in my world about what is preferred in the industry for a three position connector, a spring clamp type or...
42
16,042
Hello, A couple of questions regarding NEMA schematics and terminal block labeling. 1) I am familiar with the DIN designations for components...
3,096
