IA Tag Usage
Bob O
May 2003
1,873
IA has made it so easy for me to drag and drop tags from the Controllers that now I would like to go clean-up all the extra tags I dropped in that are not being used. Is there a way to show which tags are being used on displays?
Thanks,
Gonna say you are SOL on that one. Given all the options you have to bind tags to properties, pass parameters and reference them in expressions it's not something I think to be possible.
You would never find a tag in an expression like:
tag({plc} + "\TT" + {instrumetnNumber}), which would be looking at PLC1\TT101
Or an indirect binding of {1}\TT{2}
Use drag and drop to help build the structure you intend to use. I applications where people just drag everything in as Ignition would bring them into the system and it can turn messy very quickly.
Thanks for the replies.
I guess I will be deleting based on my memory if I used it and checking to see what's broke.
Hello, I was looking for some advice. Is there functionality within WinCC (V7.5) to report , list or export all tags that have been used within...
408
Hello I attached a screen shot from a AB Control logix PLC running Studio 5000 software. The issue that I'm having is that I cannot get my SCADA...
1,686
I am wanting to check a routine to see how often a tag is used and if it is used more than once turn on a bool for an alarm. Any ideas?
2,788
I am using old Fix32 and need to perform a cross reference on all the tags used on each screen (Picture), but can't seem to figure out a way to do...
2,363
Hello rsview experts, I have read several of threads on this site regarding tag usage and it sounds like I am probably out of luck but I will ask...
2,040
