One question about the MAG instruction Rslogix Motion
antsrealm
Dec 2010
Brisbane
207
I have a MAG instruction linking a Virtual Master with a physical slave servo with a ratio of 3. Following the command pos.
Just wondering if the position will sync or if it's just a speed / distance relationship that is maintained.
I find that over time these two slowly get further away from each other. 3 revs of the slave should equal one of the virtual. But they don't track perfectly.
With the lock position does that get the servo physically back in a synchronous position with the master or not ??
For this application it needs the ratio but also has to start and stop in the exact same position as the master.
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
165
Good morning! Let me start by saying, I am still learning about this type of HMI programming. I recently watched a video about recipes and how it...
68
I have some logic that I have written within a 5380 series controller that tracks the time an event is started, while the event is running an RTO...
91
I have an HMI 2711R - T4T Series B, and I want to know which PLCs, besides Micro 820, can communicate with it.
80
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
79
