S7-200 to S7-1200 with V10.5 Basic
blima
Aug 2010
Lisbon
96
Hello,
I have searched the website, from Siemens, but could not find a working link to the conversion tool from S7-200 to S7-1200. To install in TIA Portal Basic 10.5.
Can anyone please provide me the program?
thanks,
Bruno
Hello,
thanks,
Bruno
You might need to contact your local Siemens distributor or sales rep.
FYI the tool is a little better than starting from scratch, but your migrated program will definitely need plenty of fixing. There is plenty that doesn't convert.
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
216
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
71
Hi, I have attached herewith one image which our programmer has been used in S7 1500 PLC. Now we need to use the same instructions in S7 1200 PLC...
118
commentaire communiqué siemens s7-1200 avec vfd delta ? (cablage et sur tia portal )
119
Hi, I have a 1214 on ip 192.168.0.100. This is connected to other modules through a switch on same network. I need to connect this to a company...
170
