Siemens plc + wonderware intouch help needed
amayankrao
Jun 2012
Gurgaon
Hello Guys! Well am totally new in the world of plc....and have worked little bit on wonderware intouch v 10 and Allen Bradley plc. Now I Want to work on Siemens plc.
S7 .Please tell me the software for programming & also how to communicate with wonderware. Any freeware? Kindly make it as simple as possible as I am a complete noob thanks.
I dont know Wonderware, but if Wonderware can be an OPC client, then you can use Simatic Net software as the OPC server.
You dont write anything about the actual S7 PLC, or which networks are available.
If ethernet, then you need at least Simatic Softnet IE Lean.
If MPI or Profibus, then you need an adapter such as CP5621, and Simatic Softnet Profibus S7.
My bad JesperMP, I will be using S7-300, simatic manager v5.4 with MPI cable. So should I look for Simatic Softnet Profibus S7?! It was possible to communicate A.B. Micrologix 1000 with wonderware, Although it was a simple test circuit of lamp on/off with a switch. So I guess Wonderware does work as an OPC client. Please correct me If I am worng!
Unfortunately, Simatic Net will not work with a PC Adapter. Only with a PCI card like CP5621 or USB adapter like CP5711.
A PC adapter is not suited to a permanent solution anyway.
If you absolutely want to use the PC adapter, there are 3rd party OPC Servers that will work with, f.ex. Kepware.
Since you dont write anything how wonderware was setup with RSLinx, I cannot tell if wonderware can be an OPC client. Maybe someone else can tell.
Hello Everyone, I use PLC S7-400 with Ethernet module CP 443-1 and i want to communicate with My galaxy via DAServer. I configure my PLC with...
3,411
HI All ! I am having a problem . Please help me ! My Customer has a Siemens computer , the Operating System is WinNT WorkStation , there is...
8,298
Hi, I am having communication problem between a pc that installed with wonderware 7.11 to Allan bradley plc. This pc originally was conected...
10,424
i have two plc 1. s7-1212dc/dc/dc ip; 192.168.0.1 2. s7-1500 1513-1pn ip; 192.168.3.2 i need to get data from plc1 to plc2. any idea how to do...
93
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
27
630
