14.2.4 Identification by Color for Other Conductors.
14.2.4.1* Ungrounded circuit conductors that remain energized
when the supply disconnecting means is in the off
position shall be consistently applied as either ORANGE or
YELLOW. These color identifications shall be strictly reserved
for this application only.
Exception No. 1: Internal wiring on individual devices purchased
completely wired.
Exception No. 2: Where the insulation used is not available in the colors
required (e.g., high temperature insulation, chemically resistant
insulation).
14.2.4.2 Where color is used for identification, the color shall
be used throughout the length of the conductor either by the
color of the insulation or by color markers.
Exception: Multiconductor cables shall be permitted to be permanently
reidentified at the time of installation.
14.2.4.3 The use of other colors for the purpose of identification
shall be as follows:
(1) BLACK for ungrounded line, load, and control conductors
at line voltage
(2) RED for ungrounded ac control conductors at less than
line voltage
(3) BLUE for ungrounded dc control conductors
completely wired.
colors required (e.g., high temperature insulation, chemically resistant
insulation).
Exception No. 3: Where multiconductor cable is used and other
means of permanent identification is provided.
Exception No. 4: Where the identification of machine power and
control wiring is such that compliance with the mandatory color codes
is too restrictive for specific applications, it shall be permitted to use
additional identification at selected locations as an alternative. This
means of identification shall be permitted to be by separate color coding,
marking tape, tagging, or other approved means and shall be
permanently posted on the inside of the main electrical control panel
enclosure in a visible location.
