Is a Separate Encoder Axis Needed after Setting Up VFD Axis with Encoder Feedback?
Hi Guys, I want to connect my 1769-L36ERM to a different network domain, is it possible to do it using only the dual ports in the Controller? Or...
221
I have an existing 1756-IF16 wired as single ended with all RTNs tied together. Channels 0-3 have 2-wire loop powered devices connected with all...
1,065
I have a unique situation where we have two separate process networks ( plc, HMI, etc only). The two process networks are are owned by two...
2,149
Hi there, Quick Question. I have 2 PLCs and 2 solenoids. I would like to wire these up so that If either one turns on, it will turn on both...
4,937
I'm trying to work through a question I have about using a PLC, plus separate temperature and pressure controllers on a plastic extruder rebuild...
2,984
