I'm curious if I will find someone who has some experience with OPC UA in TIA Portal .
With a 1500 CPU you can set OPC UA Server active in the PLC. This way you can acces data with a OPC Cliënt. For testing I used the OPC UA Cliënt from the Siemens support Website, this one works well.
But..., anyone who knows how to acces the OPC UA via a CM1542, it seems unaccessible from that card. We did some tests without succes, on the CPU PN ports no problem, but via the CM1542 no succes..
Anyone experienced the same ?
Thanks in advance,
Kind regards,
Combo
Thanks in advance,
Kind regards,
Combo
