Vijoe designer with Ethernet connect Touch panel Maglish
ismail88
Sep 2010
belguim
My question are how can i connect vijeo designer with ethernet with my touch panel.
My ip from computer are 192.168.1.4 I have taken for touch panel 192.168.1.5 (I'm not sure that is correct or how take you ip adres for touchpanel)
but if I download he don't find my touch panel ( Error )
you must specify the target ip adress. click once on target and then in the properties box select download to ethernet and specify ip adress
Some of the Magelis touch screens also have a compact flash card slot, so you can put your project onto the compact flash, insert the CF into the panel, and download the program that way.
You need to go to make sure your IP address of the HMI is on the same subnet, then you can do a download to the non virtual hmi
I see you dont have to use compact anymore. with the new firmware and hmi with usb port you can use normal memory stick as data storage option. makes life alot easier and cheaper
How do I organize the template for my controls. I am new to Logix Designer but have used RS500 and RS5000. My new Logix Designer has Toolbars...
224
Hi, I have questions. I have Analog Input that need to put into Ignition Designer. But I don't know how to put?
105
Good Day all. I am currently busy with a schneider HMI design in vijeo designer and i want to know how you can animate an image to move on the x...
142
Hello, Im building project with 1756-L82ES controller and 1756-IB16S card but i cant find it when trying to add the card to IO configuration...
134
Does anyone know how to set the background colors of instuction blocks (TON, MOV, etc)?
130
