2 Duty and 2 stand by Pump Logic in RS logix 5000
Go to the downloads section of this website (links at top of the forum) and there will be some info to get you going.
If you want a turn-key AOI/routine, please supply your purchase order number.
This is a simple no-frills code I got my apprentice to do a few years ago, it was a retrofit of an old relay-based system and worked well, the apprentice was given the task to build a new panel insert with a small plc & HMI the criteria was to have a selection on the HMI with 4-way selection for OFF. Duty 1&2 Duty 3&4 and duty 1 2 3 4. with hours run counters on HMI for the pumps only some of the logic is shown but it is obvious, this plc was a small Mitsubishi so the counter was derived from a simple 1-minute timer adding counts to minutes & hours and simple logic for pump runs. Note in this case timers were used to cascade the start of the pumps but should give you some ideas.
Dear Friends, I am an Elect Engineer from Low Voltage and absolutely a beginner in PLC. Any of you please help me in Selecting A PLC and...
2,972
Hello Friends, I am looking for a way to take my PID Output( it is the result of my PI Algorithm in Real format) and generate a PWM Signal in...
2,582
Just want to make sure my thought process is correct before I proceed. I have a linear actuator with a 3min / 17min duty cycle (3 on, 17 off) I...
1,160
I have an electric actuator with a 75% duty cycle. I am sending an analog output from a PID to a controller board on the actuator. My concern is...
2,439
can anyone help me understand the basic operation of 2 duty and 2 standby Filter bed operation in STP. There will be 2 duty D1 & D2 and 2 Standby...
1,550
