plc storereviewsdownloads
Reply
Thread Tools Display Modes
Old September 13th, 2021, 10:25 AM   #1
arvind_g
India
arvind_g is offline
Dataman 8700 and Micro800 communication
Hello all..
I am presently working with a Cognex Dataman dm8700dx-e (ethernet) scanner and need to make it communicate (read data from) with a AB Micro850 Plc. Have spent couple of days looking for a way to read scanned data from the scanner into the PLC; but no success yet. Please share any information / thoughts / insights if this can be done and how to if it is possible.
I could get the same scanner work with compactlogix pretty easily but am stuck with the Micro 850 and CCW.
Any help is much appreciated and thanks in advance for the same.
Arvind G
Old September 13th, 2021, 12:07 PM   #2
drbitboy
United States
drbitboy is offline
drbitboy's Avatar
Can you share the logix 5000 code, including as a PDF?
__________________
i) Take care of the bits, and the bytes will take care of themselves.
ii) There is no software problem that cannot be solved with another layer of indirection.
Old September 14th, 2021, 01:33 AM   #3
arvind_g
India
arvind_g is offline
drbitboy,
There is nothing to post for logix5000, I just added it as an Ethernet module to the io configuration and it's working with the compactlogix after little tweaks in the dataman software. Is it that I will need to use CIP generic / symbolic messaging in CCW to make it talk with Micro 850 ?
Thanks,
Arvind G
Old September 14th, 2021, 09:38 AM   #4
pturmel
United States
pturmel is offline
Try using messaging to the Assembly objects' buffers. CIP Get/Set Attribute Single. Class 4, Instance==assembly #, Attribute 3.
Old September 14th, 2021, 11:00 AM   #5
arvind_g
India
arvind_g is offline
Pturmel,
can you please elaborate a little more , I need a little more guidance as I have not done the messaging before.
Sorry for my incompetence.
Thanks,
ArvindG
Old September 14th, 2021, 03:25 PM   #6
pturmel
United States
pturmel is offline
Hi ArvindG,
Take a look at this draft:
https://www.automation-pros.com/plct...rvind_g.ccwarc
It assumes the Dataman input assembly is #100, and output assembly is #150. Adjust the local variables as you need.
I haven't had to use any Micro8xx devices yet, so the above is completely untested and certainly incomplete. (You'll at least want a timer to pace the messaging.)
Old September 15th, 2021, 01:36 AM   #7
arvind_g
India
arvind_g is offline
pturmel,
thanks for the pointers, I will certainly look into the CCW project and post my findings.
Thanks again,
ArvindG
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
