kouim92kostas
Hello everyone...
I'm working on a project where I want to use the time of the PLCs to do a specific process.
In both PLCs (cpu 224 & cpu 315) I can take the time of PLC and use it as I want. The problem is when the time changes (from the summer time to winter time and vice versa).
As i saw, in the menu of Time of Day Clock, on both PLCs I can change the time only if i sychronized it with the PC i connect with. There is a menu as I see, but its not enable the button.
1) Why is this happening? For example in CPU 224XP it has a menu where I can set it up this change time. But in 224 I can't. The same in CPU 315.
I was thinking to create a program where automatically change the time but I don't know how!
In CPU 224 for the reading time i used this:
TODR VD920
MOVD VD923, VD910
LDW= VW910,VW530 (VW530 is the time I want to open a valve)
A second though is to send from the the SCADA a time (the time of the PC) to the CPU 315 and CPU 224. But my problem is where? So it can keep it and sychronized it with the clock of each PLC....
TODR VD920
MOVD VD923, VD910
