control of a vertical gantry using s7-200 and a stepper motor control board
sala
Feb 2008
arima
Hello to all.
I need some help in controlling a vertical gantry using a s7-200 with only I/O digital ports and a ST400NT stepper motor control board. the gantry stops at different points due to opto-switches.
I would like to use distributed control where the plc tells the motor control board to start and stop. I am a novice at plcs so can someone please respond or it would be most appriciated if a sample code can be given to me
thank you(the board can be viewed on http://www.rmv.com/st400nt_mi.htm)
the board as one of its features can be controlled using serial link, can the s7-222 cpu with I/O control a motor controller board like that?
So the customer purchased a Mitsubishi drive, in the same project for a different pump they got an ABB drive, was literally whatever they could...
45
Hello, I am a plc engineer and I have a job to do in the NIGERIA 25000 TON GRAIN SILOS STORAGE CONTROL PANEL. A problem where the panel is not...
116
Hi all, I am upgrading a couple of 2094-BC01-M01 servos with 2198-H015-ERS. The original code uses MSG instructions to control (release, engage...
90
Hey there guys, I'm relatively new to PLC programming. I had a few basic classes in college but since then I have mainly been on the instrument...
238
Hi, Is Control Expert V15.0 supposed to support multiple monitors? I'm running Control Expert V15.0 on my host Windows 11 PC, connected to two...
91
