communication of micrologix 1200 modbus
vikas1947
Jun 2011
india
172
i have a micrologix 1200 i want to know that if i change my channel 0 to mod bus rtu master or slave and then i have to program the plc so in rs linx which driver i have to chose please tell me the appropriate way to program the plc
once you swap it to modbus you cant do anything with linx. You have to use the default comms button to switch it back to AB protocol to go online with linx.
I don't have any prior experience with MicroLogix so the Communication Toggle Button is new to me. We currently have a few MicroLogix that are...
2,187
Hi all I have micro logix 1200 and automation direct panel (EA9-T6CL). I have downloaded .RSS file in micrologix 1200 using 1761-CBL-PM02...
1,795
problem in communication between micrologix 1200 & Panel View 600 Plus by serial DF1 Hello Friends i have to do communication between micrologix...
6,603
Hello All, We have a MicroLogix 1200 series controller on a package in our plant. We need to connect a serial device to MicroLogix 1200 for...
4,603
Good Day All, I've a MicroLogix 1200 and Panel View 300 Micro installed on a package in process and its working fine. PV is connected with 8 pin...
3,589
