Repacing some SLC 500 with CompactLogix-Would you use 1769-OF8C or 1769-OF8V in Panel
Cydog
Feb 2018
Maryland
313
Good Afternoon ,
I'm going to be replacing a few SLC 500 PLC's with CompactLogix this year. I would like to keep the PowerFlex 70 Drives in the panels , but eliminate Devicenet and go with analog controls for now. The new PLC and the old drives will be in the same panel.
My question is , would you guys use an Analog 0-10 VDC 1769-OF8V or 4-20 ma 1769-OF8C in the cabinet to control speed ?
Thanks so much ,
I always use 4-20mA for my analog. A voltage signal can be affected by wiring distance and even induced voltage from other devices in the panel.
If you are making a change anyway why not change the drives to ethernet it's jus a card swap in the drive
I think it would be quicker and simpler to setup
Thanks . Yes , I did that with a project early last yesr , but I had the luxury of replacing all the drives with Powerflex 525. I used ethernet with those , but keeping these old Powerflex 70 drives , they just seem so difficult to get around . We are a 24/7 plant I want the maintenance staff to be able to change these out fairly easily .
Thanks for your advice ,
For drives inside the same cabinet, I prefer to stick with voltage signals. Voltage is easier for most people to troubleshoot since you don't have to break the circuit or have a more expensive meter capable of measuring mA current.
Just replace the 20-COMM-D (DeviceNet) with a 20-COMM-E (E/IP) or a 20-COMM-ER (Dual Port)in the drive. I think remapping the I/O to and from the drive would be a lot less work that converting the signals to Digital and Analog I/O. Hardware and software wise.
I’m attempting to send a temperature from a SLC-5/02 to an EZiMarquee display. The vendor said to use a MSG instruction to send the data to the...
83
Hello all. I have a few SLCs in my plant and of late we've seen a weird issue: The system will be running normally and then randomly the outputs...
97
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
103
I have a redundant ControlLogix being set up. This program reads a value from a remote site which happens to be SLC PLC. Rockwell mentions SLC...
96
Hello, I have a ControlLogix redundant controller being set up. The program reads a value from a remote site which hosts a SLC PLC. Rockwell...
80
