Reports with FTV SE
JonAW
Sep 2013
Somewhere
121
Hi Guys,
I'm looking to do a small 1 page report with every batch run through a system. There is a maximum of 100 parameters. I have the system logging to a ms Access database and filtering the records through ftv se via VBA. Now I want to double click on a record in a list box which (hopefully) will open a report containing all the approprriate data. From there I'd like to print the report. Is this possible with factorytalk view se without opening another program? I've tried experimenting with PrintDisplay but this doesn't print ActiveX component values.
Any advice? If necessary i could use a form / report in access but would prefer to keep everything contained in the one program.
thanks
Jonny
I made a mistake on the first post. I accidentally copied over a button which I used to clear the listbox as my print display button. When I took out the coding to clear the listbox everything worked fine.
Hello Everyone, I am working on reports in Vijeo Citect V7.40. I want to generate a report whenever I press the button. I am able to generate it...
871
Any advice on below issue? ➢ IFix 5.0 with USB Hardware Dongle License Standalone application connected to RX3i PLC units via Ethernet (bridged...
1,616
Hello Guys, I spent some time searching the web to learn how to generate the report (to be printed out or to be saved as pdf file) which would...
1,205
Hi all, I have created a report using a report writer in Indusoft scada, but i just wanna know can i import the Bargraph symbol which is...
1,200
si'm looking for a small,inexpensive, touchpanel HMI that can connect to a printer to print simple text reports. The HMI will read data from a...
2,214
