Protocol 3964R RK512 Profibus convertion & communication
Apel
Aug 2007
Singapore
98
Hello everyone,
I have an interesting application to share with you all.We need to communicate one Schenk Wigher system-MULTICONT 0050(which is presently communicating with Interbus-S through a converter gate).Now the client is replacing the Interbus-S system with ABB system.ABB system having profibus-DP.MULTICONT0050 supports only serial protocol called RK512(3964R)through RS422 port.So the objective is to Convert this RK512(3964R) protocol to Profibus-DP protocol.We are going to install one Siemens S7 300 CPU 315-2DP and one CP341 with RS422 port to convert this serial protocol to Profibus-DP and vise-varsa.
Before the actual shutdown of the plant, I need to confirm that it can work.I make a TEST to communicate between 3964R Protocol modules by using one CPU 315-DP, one Cp340 and one CP341.like below skecth:
CP340----------<<<---3964R protocol---->>>-------------CP341
Its communicating very nicely, but I dont know how to read exact value from one data block and to send exact value from a data block.
Objective:I want to receive/send particular value from/to partner Datablock.
can anybody help, any suggestion welcome
thanks
Dear All, I want to communicate with Arburg Selogica controller v3.09 of an old Arburg injection molding machine. The protocol by which this...
2,620
Hello Gents, I am trying to interface a prosoft MVI56 card to another machine using the 3964R protocol (the other machine is acting as a master...
2,241
Hi all Trying to remotely connect to a TIA Portal PLC. I can ping it without a problem but can't get my software to connect. I've opened port...
326
I’m working on getting a Parallel Redundancy Protocol PRP system set up in a lab situation. The L73 PLC is in rack 4. 3 io racks are 1,2,3. I...
752
Does anyone have information or documentation regarding the protocol used in Rockwell's Remote IO, and how the physical layer of the network...
929
