honeywell transmitters
mobil1syn
Dec 2018
socal
79
got a customer spec asking for the following. never used honeywell stuff or even heard of an instrument having a heater box. so is a heater box just to the the sensor from extreme temps and avoid condensation? having a hard time finding any information on the honeywell web site and havent heard back from a rep yet.
• Honeywell transmitters series 800 , HART 7 Configuration, with manifold and heated instrument boxes (as an option).
You can start at Honeywell's site for the ST800
https://www.honeywellprocess.com/en...nsmitters/smartline-st-800/Pages/default.aspx
Honeywell will sell a manifold valve or an instrument valve, but it's not their standard product.
To my knowledge Honeywell does not sell heated enclosures. If they do, they buy them like you would and mark them up.
A Honeywell distributor is likely to be able to handle the combination of transmitter, valve and enclosure.
Parker heated enclosure:
https://www.parker.com/Literature/Parflex/4200-Heated-Enclosures.pdf
OBrien heated enclosure:
https://www.obcorp.com/product/instrument-enclosures-protection
re-reading my original post, it appears i wasnt clear.
the transmitter and block n bleed, is no big deal. the enclosure was the issue. thank you for the information danw. what is the purpose of the heated enclosures? im from socal, so cold protection is not something im familiar with.
Keeps the device out of the weather. Even though the instruments are NEMA 4x, when there's snow and ice covering the unit it's a pain to to access and work on.
An enclosure offers some minor amount fire protection, some resistance to corrosion exposure, and limits UV exposure. The current breed of Honeywell PTs have an ID plate on the top of the unit that is painted, not engrave like in the past, and UV exposure renders it unreadable in about a year outdoors. An enclosure will keep the UV off the ID plate.
We sell more sun shields than enclosures.
http://www.oilandgastechnology.net/sites/default/files/INTERTEC Brochure.pdf
It might pay to ask what the main purpose of the enclosure is.
Hi Anybody knows how to enter Honeywell HMI config menu. I need to change date and time of HMI. HMI series: Honeywell HCi series
106
Hi all. Would anyone happen to have the Modbus register datasheet for the Honeywell/EnergyICT EIMFlex Modular Meter v1.11 We've 40 of these that...
62
Hello, I am learning to create shapes and VB Scripts in HMIWeb Display Builder. I wanted to change color of my rounded rectangle by script. I...
101
Hey Guys, I am getting random rack/slot errors. I go to download and everything is ok but then it has a error. For example - Yesterday everything...
361
Hello Guys, I'm working on Honeywell HC900. I am using the PID block. I have attached the Switch and loop block to it as well. I have attached a...
624
