plc storereviewsdownloads
Reply
Thread Tools Display Modes
Old September 15th, 2019, 08:14 PM   #1
yard1e
Portugal
yard1e is offline
Reading encoder for input/output and limit reading
Hi, I'm just a complete newbie on ladder logic and plc programming and I started a few weeks working with that, also it's my first post here, I'm working with an omron plc and I have an encoder attached to a rack and a pinion that reads the move of a component that is moved on a rail with a motor.
The encoder sends a signal ranging from 0 to 10v and I already set the limits physically on the encoder, but I need to measure that component distance outside of the range from a reference point in millimeters. First I need to convert the position in millimeters (I saw scl and apr functions but I don't get how I proper use it) so in an HMI it shows the proper distance that this component is placed at a reference point, set limits so this component so it only rides forward and backwards on that range and let the user input a value in millimeters so it travels to the desired position.
I tried to convert the signal in milimeters with a couple of mathematical operations but I think scl or apr is more suited for that operation, I have the conversion working but I think it can be optimized.
Another thing is that I need to store the current value because it oscillates and I'm using a compare function <> to check if the value has been changed to call the move function, probably here's another good way of doing it with switches.. I dunno.
The last thing is I need to reposition the component because when it reaches the value it travels a lil bit further so I need to make it go inside an approximated value (-1mm or +1mm).
Is anyone here that have done something similar and could help me out? It's my first post here and I'm already asking for too much... I did a research over the internet and here but could not find anything similar for my problem...
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Rslogix5000 PID CV Low Limit adjusting p_logix LIVE PLC Questions And Answers 17 February 27th, 2017 12:57 PM
Encoder Based Part Tracking - Bi-idirectional Travel Veteranpete LIVE PLC Questions And Answers 7 November 8th, 2015 02:48 PM
MICROMASTER 440 + profibus + encoder + limit switches AlecTek LIVE PLC Questions And Answers 0 January 13th, 2012 03:10 PM
Incremental Encoder Application Don_Dubé LIVE PLC Questions And Answers 16 March 23rd, 2005 08:22 AM
does the gear box affecting the positioning value???? common LIVE PLC Questions And Answers 3 July 6th, 2002 05:11 PM
