OMRON NC113 Module to HIWIN Servo Driver
romerqazwsx
Sep 2018
Laguna
Good day,
I am having a problem with outputting pulse to the HIWIN servo driver using the OMRON NC113 module.
The NC113 module is already outputting a pulse but the HIWIN servo driver wont recognize it. I am already sure about the settings on both the NC113 and HIWIN servo driver.
Here is my wiring.
NC113 Wiring (open pulse collector):
Here is the wiring on my HIWIN servo driver:
I9 and I10 ports are described on the manual as:
and the manual gave this wiring when using pulse command through host controller (single end) which is A6 and A8 on NC113:
This is the parameter setting on the HIWIN servo driver:
Thank you very much in advance!!!
3,446
Hi There, I have couple of Omron PLCs connected on my kepserverex and my intouch reads data from kepserverex. I have been observing that roughly...
87
Hi dear . I have a system with cj1m cpu11 etn. previously NT 5z HMI was connected with plc. recently my old HMI got damaged. I want to replace it...
89
Omron AD081-V1 Analog Input Card Offset & Gain Adjustment Entering Adjustment Mode 1. Set the input card in adjustment mode (Turn ON Dip SW No-1)...
54
I am working on a project using a NB screen and NX1P2 PLC. I am having a really hard time getting a real number to properly translate through to...
116
