cx designer project
aPLCable
May 2018
NI
Hi guys,
Could anybody check if they can open the attached hmi project in cx designer,
I have tried with v3.69 and get the project not found message.
Have did this before fine but having issues with this project received by email
The .zip file only contains the .IPP file.
There is also a folder of the same name that contains the data files for the project.
They need to zip that folder and send it to you.
Put both in the same folder on your machine.
Hope this helps.
Hi, I received the following project from a customer on a QuickPanel Proface 6" that I need to swap to a Siemens Panel. However, I cannot seem to...
332
I work for a used industrial machinery merchant. We try to get uploads from all our machines for future customer support and security. Can some...
1,764
Hello, I'm using View Designer 7.01 and experience anomalies in project explorer. When I move mouse cursor over project explorer, highlighted...
2,519
.... is taking 2 minutes and 18 seconds to save an (almost empty) project, located on my local hard drive. This is seriously going to hamper...
1,399
I have got E950 (probably it is "branded" version of E910) panel it came with flash card. I wonder if there is any way to restore project since...
2,597
