Siemens PC-HMI Cable
IdealDan
May 2017
MA
480
Hi guys,
Which Cable do I need to connect to a Siemens ESA XB300BF4R070 Workstation so as to upload file from it please?
I believe it's an industrial computer, so there wouldn't be one.
I think this is what you have:
https://www.esa-automation.com/en/products/ipc/box/xb300/
Yes Bro,
the issue is that it hangs like a corrupt Operating System does, I need to backup and may be Format it, OR is there a work around to this hanging issue?
Please tell me,
HOW CAN BACK UP THE HMI SCREENS?
I will also need to get hold of the O S for re installation.
Regards
This is what I posted in your other thread:
The computer itself is not from Siemens.
I think you should be able to install standard Windows 7 Professional 32-bit... but you would also need the HMI software and project, as well as any add-ons, databases, utilities, etc. that the application is using.
If your computer is out of warranty, I would take a backup of the complete hard disk, and scan it using the manufacturers hard disk checking tool. If it shows problems, get a new hard disk and restore your backup to it.
Hi Complete newcomer to S7 so go easy on me... Siemens S7: What cable do I need to connect S7-1200 PLC to HMI? The touch screen is one of these...
2,536
Hi people! Do anybody have drawings for making serial cable for SIEMENS HMI, exactelly OP17. I have SERIAL RS232 cable but 9-9 pin; and I...
18,365
Buona sera, Ho dei problemi nell' interfacciare PLC S5 con HMI 2a Gen. Siemens (ad esempio KTP400) tramite IBH Link S5++. il mio obbiettivo è solo...
93
Hello colleagues, On a Siemens Multi panel (MP 377 12") of a machine (S7-300) at a customer's site, some parameters need to be changed that have...
281
Hello all. I have an ESA HMI that is connected to a Simatic S7-300 (CPU312). I have uploaded the program from the PLC which is written with Step7...
1,429
