1756 L63B AB plc to PSS 3100 comunication problem
Ritu
Sep 2013
Pune
Dear all ,
i am using 1756 L 63B cpu and 1756 CNB controll net scaner and comunicate with Pilz PSS 1 DNS (device net sacner ) now i am having problem with comunication . Pilz satus network LEB blinking . in RsNetworks found all healthy
please suggest ....
Welcome to the Forum !
Please tell us more about the Pilz controller.
ControlNet and DeviceNet are physically and electrically different, so there must be something in between them like a 1788-EN2DN or other bridging interface.
Is this a system you are commissioning for the first time, or a system that worked in the past that you are troubleshooting ?
Thanks for relay sir ...
I am troubleshooting the problem.
communication is in bet 1756 DNB AB scanner and Pilz PSS 3100 both are device net controller .
bec initially i found a problem with ESD file, then i down loaded from net . now in RSnetwork device net it shows healthy .but still Pilz PSS 3100 status network LED blinking .
is it problem with Address mapping ?
how to mapp address ?
in the pc i found a DEvice net program with .dnt file format
how to load this program to device net controller ?
I am beginner for AB plc please guide......
Can someone give me the differences of the two processor in terms of usage and functionality..
3,133
Hi, I have two quick questions: 1- Could I use 1756-IA16/A with TTL inputs? Sourcing (PNP)? Sinking (NPN)? Either one? 2- What does /A in the part...
138
Hi all, installed on chassis A17 an A/I from Allen-Bradley , problem is what ever I do , all channels are sticked on value 39.9 and cannot change...
131
Hi, Is it possible to for an RIO with Flex 5000 series module, e.g. 5094-AEN2TR, to communicate with an 1756-L72E processor.
86
please using the usb can i assign any ip address that i want ?
147
