Produce/Consume data from a WAGO 750-881 with a CompactLogix controller
Lovell
Feb 2013
Saskatchewan, Canada
120
I have been trying to setup a connection between a 1769-L33ER and a WAGO 750-881. The WAGO PLC is part of vendor equipment. I set up a Generic Ethernet Device with the correct IP, INT data type, input 110 - size 4, output 111, size 4, config 1, size 0.
Always errors on invalid size. I tried SINT type as well. Has anyone done this successfully? If so what were your Generic Ethernet Device settings?
Thanks,
I have a client who periodically experiences network communication issues. Sometimes when I VPN into the site, their SCADA systems will flash comm...
169
I currently have a setup in Siemens S7 using I-Device connections over PROFINET and I am trying to investigate an equivalent setup using Rockwell...
1,122
Recent Forum member and very-good-question-asker /DesertSurf520 has a thread that started a discussion about Compact 5000 I/O, but branched off...
1,854
My PLC has a Boolean consume tag that gets data from another PLC via ethernet. Is there a way to make the consume tag fail to 0 when the ethernet...
2,753
Hello Ladies and Gents, I have some PLC to PLC communications using Produce and Consume. The data is not time sensitive, and I really only need...
16
4,651
